SD Android Scale Button - make it work like iPad version ?
http://forums.skydemon.aero/Topic16632.aspx
By Boycey - 4/9/2017 6:39:31 AM
srayne - 8/10/2015 2:10:14 PM
Easy Cruising (8/10/2015)
Now that's what I call service !
.... and already available in today's Beta !!
By Boycey - 4/9/2017 6:42:32 AM
I don't have the scale showing on my Sony z3?
V‌ery infuriating, a map with no scale is pretty useless..can't find a setting for it anywhere.
A‌lso in flight mode the skydemon logo obscures the groundspeed. Any thoughts please?
By Boycey - 4/9/2017 6:44:40 AM
Any way to send a screenshot?
By tnowak - 4/10/2017 8:04:13 AM
Map scale doesn't show on small display devices. I have the same issue‌ with my Samsung S3 Galaxy.
If you press and hold the +/- button (lower left corner on my display) it always resets the map to 1:500000‌‌ scale.
Tony‌
By Boycey - 4/10/2017 8:08:16 AM
Tony‌
By Boycey - 4/10/2017 8:11:10 AM
Tony‌
Hi tony
you can change the default scale in settings/‌‌‌‌planning options/preferred ma[p scale you can change it.   However thiat doesn't solve the issue of lack of scale on screen, or the Logo obscuring GSpeed!
By Tim Dawson - 4/10/2017 2:39:19 PM
Please don't dig up threads from 2015.
If you use SkyDemon on a device with a small screen, there may not be enough room to display as many items on the screen as there would be on a larger-screened device. Some items are not displayed at all, such as the map scale reading. If you find that the logo is obscuring one of your instruments, reduce the number of instruments onscreen.
By Easy Cruising - 8/10/2015 10:41:34 AM
I am using SD 3.3.2.20289 on Samsung Galaxy S5. It's a great tool. I have a suggestion :
When hitting the orange 'Scale' circle the Android version of SD does not automatically show the currently selected scale in the 'list' of scales. This functionality does work on the iPad version of SD. The issue is that, especially during flights, the next scale you want is probably 1 or 2 scales up or down from the one you are currently on, so the currently selected one should appear in the middle of the scale window. Otherwise, you have to scroll up from 1:2500 every time. That's an issue if, like me, you have the S5 in landscape mode, because the 'Scale' list only has space for 3 entries .. so it's somewhat 'fumbly' to get to the one you want, more so in turbulence.
Just wondering if this can be done for the Android one, or whether it's a limitation of the Android platform (since it works nicely on iPad) ?
