Altering my route
http://forums.skydemon.aero/Topic16430.aspx
By tnowak - 7/22/2015 8:31:38 PM
SD Android (latest version ) on Samsung Galaxy S4 and Nexus 7.
If I create a route between two airfields and then want to insert a turning point (example to select an en-route VRP to keep clear of CAS) should I be able to do it by "dragging" the magenta line with my finger? I can't get it to do this on both devices.
I can only amend my route holding my finger on the screen (over the required VRP/waypoint), selecting the description in the "What's Here?" popup and selecting "Insert into route".
Tony
By tnowak - 7/23/2015 12:07:44 PM
Okay - I have figured out what was going on.
Most likely I wasn't being accurate enough when touching the magenta line (I have normal fingers!).
I have just tried again on my Samsung S4 (in Planning mode) and can get these results:
1. Can drag the magenta line to a new intermediate point.
or
2. I get the popup "What's Here"
or
3. Move the map around.
The dragging of the magenta line seems to be the most tricky to achieve consistently, though at least I know it works.
Thanks for your help.
Tony
