By GraemeH - 1/14/2011 8:25:23 PM
Is there a quick way to disable winds aloft in the plan? I know on the leg options I can specify it manually, but I'd like to be able to turn off auto wind calculation globally.
--Graeme
By Tim Dawson - 1/20/2011 12:26:21 PM
Yes that is the case. I'm not sure if we'll be able to get the requested change into the 2.0 version, which is pretty much locked down now, but we should be able to introduce a more complex model that allows you to specify the IAS/TAS/fuel flow for different altitudes per power setting in the next version.
