Route change bug
http://forums.skydemon.aero/Topic1583.aspx
By stuartforrest - 1/7/2011 9:35:02 PM
I just opened an old route and went to change the route level from the default route height and when I unticked the box to activate typing in a new level I got and unhandled exception and this is the error below. It is todays beta.
System.ArgumentException: TimeSpan does not accept floating point Not-a-Number values.
at System.TimeSpan.Interval(Double value, Int32 scale)
at Divelements.Aviation.Routing.FlightModelUtilities.ProcessIntermediateClimbOrDescent(List`1 entries, Int32 targetIndex, Boolean climb, IFlightModelDataSupply dataSupply, FlightPerformanceClimbProfile climbProfile, FlightPerformanceDescentProfile descentProfile)
at Divelements.Aviation.Routing.FlightModelUtilities.ProcessIntermediateClimbsAndDescents(List`1 entries, IFlightModelDataSupply dataSupply, FlightPerformanceClimbProfile climbProfile, FlightPerformanceDescentProfile descentProfile)
at Divelements.Aviation.Routing.FlightModelUtilities.RunFlightModel(RhumbLineLeg[] legs, IFlightModelDataSupply dataSupply, FlightPerformanceClimbProfile climbProfile, FlightPerformanceDescentProfile descentProfile)
at Divelements.Aviation.Routing.Journey.CreateModel()
at Divelements.Aviation.Routing.Journey.get_Model()
at Divelements.Aviation.Routing.PlannedRouteParameters..ctor(Journey journey, GeometryEntity[] airspace, Entity[] positionedEntities)
at Divelements.Aviation.FlightPlanner.Routing.x623a54d0e478ee0f.xa3c6ce19704d4032()
at Divelements.Aviation.FlightPlanner.Routing.x623a54d0e478ee0f.x2f58c73044db3fb6(Object xe0292b9ed559da7d, RouteChangeEventArgs xfbf34718e704c6bc)
at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
at Divelements.Aviation.Routing.Journey.OnRouteChanged(RouteChangeEventArgs e)
at Divelements.Aviation.Routing.Journey.EndBulkChanges()
at Divelements.Aviation.FlightPlanner.Routing.x8f2e50e5eedec15c.x1ab74ffda0bc2fb6(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 1.4.5.20583
Win32 Version:
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
System
System.Drawing
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Assembly Version: 1.0.4024.20581
Win32 Version: 1.0.4024.20581
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Divelements.Mapping
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
Assembly Version: 1.4.3.1
Win32 Version: 1.4.3.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
By stuartforrest - 1/14/2011 11:00:46 PM
Great
