How to select runway on iPhone for extended centerline
http://forums.skydemon.aero/Topic15778.aspx
By joseffe - 5/19/2015 8:15:55 AM
Hi all,
While in flight I can use the "what's here" menu on my ipad to display the runway layout and switch between active runway in case it differs from skydemon's suggestion. How do I use this feature on my iphone as there is no runway layout available - probably due to limited space of the display.
Thanks,
 Oliver
By Tim Dawson - 5/19/2015 8:54:17 AM
You can't nominate a specific runway, but you don't actually need to. All extended centrelines are displayed and there is currently no special behaviour once a specific runway is nominated other than the pseudo-ILS kicking in earlier. It will still kick in when you reach your intended centreline.
