Loading Setup from Cloud on PC (V3.0.0)
http://forums.skydemon.aero/Topic15640.aspx
By srayne - 5/8/2015 7:36:16 AM
Loaded setup from cloud to PC and got an unhandled exception error followed by the following in W&B window:
Copy of "C:\Users\me\AppData\Roaming\Divelements Limited\SkyDemon Plan\settings.xml" attached FYI
By srayne - 5/8/2015 11:18:39 AM
I spoke too soon....if I save to the cloud from latest Android Beta then load into PC I get the error sometimes!
System.NullReferenceException: Object reference not set to an instance of an object.
 at Divelements.SkyDemon.Briefing.WeightBalancewindow.LoadingPointGridRow.GetCellValue(GridColumn column)
 at Divelements.SandGrid.GridRow.DrawCells(RenderingContext context, Rectangle bounds, GridColumn[] columns, TextFormattingInformation[] textFormats)
 at Divelements.SandGrid.GridRow.DrawRowForeground(RenderingContext context, Rectangle bounds, GridColumn[] columns, TextFormattingInformation[] textFormats)
 at Divelements.SandGrid.InnerGrid.x14295bd0cde2ff5d(RenderingContext x0f7b23d1c393aed9, Boolean x48d1c33294a7dd40)
 at Divelements.SandGrid.InnerGrid.x7f63857195e5d213(RenderingContext x0f7b23d1c393aed9)
 at Divelements.SandGrid.SandGridBase.OnPaint(PaintEventArgs e)
 at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
 at System.Windows.Forms.Control.WmPaint(Message& m)
 at Divelements.SandGrid.SandGridBase.WndProc(Message& m)
mscorlib
  Assembly Version: 2.0.0.0
  Win32 Version: 2.0.50727.8009 (FX35W81RTMGDR.050727-8000)
SkyDemon
  Assembly Version: 3.3.0.34021
  Win32 Version:
  CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe
  Win32 Version: 2.0.50727.8008 (FX35W81RTMGDR.050727-8000)
System
System.Drawing
  Win32 Version: 2.0.50727.8007 (FX35W81RTMGDR.050727-8000)
Divelements.Aviation
  Assembly Version: 3.3.0.34019
