By tedhagen - 4/7/2015 11:28:28 AM
1. Im trying to add a WT-9 as a profile, but how do I adjust the moment arm for the fuel? 2. Does it matter if I use mm instead of inches? As long as everything is in the same unit that should be fine, right?
/Ted
By DirDej - 4/7/2015 3:28:43 PM
it should be in the Edit xyz profile > Fuel Tanks > Fuel xxx liters > press > Lever Arm ...
