Edit Route
http://forums.skydemon.aero/Topic14649.aspx
By lhe - 3/7/2015 10:57:29 AM
In the Android version of SkyDemon, there is an "Edit Route" menu item that opens a box where you can textually change details of the route.
Question: How do I access this function on the PC version of SkyDemon? As far as I know this function is the only way you can add an alternate airport after a route has been created. I am using SD 3.2.1.0 on the PC.
Problem: If I use this function on the Android version of SkyDemon with a multi-flight route, all flights except the currently selected one disappears. (Even if I only change the route part and not the departure/destination airports.) I am using SD 3.2.1.22629 on the Android.
By lhe - 3/28/2015 4:12:41 AM
Thanks!
It is a bit tricky that SkyDemon has slightly different menus etc. on different platforms.
