By Oliver Voigt - 11/30/2014 9:58:32 PM
Hallo all
Was it possible to adjust the QHN, to geht the real altitude?
Can we mark/change the reporting points a little no viewable. Maybe bigger and a better signal color?
And one private wish: Our airport was not ETLC! Have a look: http://de.wikipedia.org/wiki/Fliegerhorst_Kaufbeuren
normally it was ETSK
By Tim Dawson - 12/8/2014 5:09:47 PM
What did the other product actually do, once you had entered the QNH? I don't understand the potential benefit of this feature. It is unlikely we would ever make use of an on-board barometric sensor because the output from cockpit static pressure is unlikely to be of any benefit. It won't be accurate because it isn't connected to the static line.
