By lhe - 11/9/2014 9:41:04 AM
Swedish NOTAM ES/B3264/14 is not correctly charted in SkyDemon. The affected area is along a line between two coordinates. SkyDemon charts this NOTAM as a circle centered on one of the coordinates.
The NOTAM is about laser radiation from a light show, and although you can't tell from the NOTAM, the coordinate where the lasers are located is NOT the one marked with a circle in SkyDemon, nor is that coordinate included in the circle area.
If SkyDemon can't show the affected area as a line, then I think the next best solution would be a circle centered on the midpoint of the line and having a diameter equal to the length of the line.
By Tim Dawson - 11/11/2014 3:47:06 PM
No, it isn't, sorry.
