France flightplan not reaching all addresses
http://forums.skydemon.aero/Topic13240.aspx
By pink leader - 9/9/2014 9:11:30 AM
A few times, colleagues and I have found that when we go to activate a flightplan in France filed via SD, the French say they have no knowledge of it. Going again this week and will see if it happens again.
At the Flying Show, I discussed this with the NATS/AFPEX team as well as with SD. It appears that AFPEX had the same problem. They started by just sending to the French hub (as formally requested) and same result. FIX - add addresses of departure airfield and regional ATC automatically as belt and braces.
I wd like to do the same and see I can do this in SD ... BUT pl can someone tell me where I can get a list of addresses in Flightplan speak. Indeed perhaps SD could have a "+" button that comes up with probable addresses dependent on departing French airfield.
So far not been prevented from flying but it is a bore.
Anyone else had the same thing?
David
By pink leader - 9/15/2014 10:03:07 AM
Hi Tim
Worked fine for me last Sat. Cancelled a FPL for Sunday and put up new one for Sat to return from France. Took off 15 mins later and Lille Info had all details.
Tx for info
D
