Alternate leg in route
http://forums.skydemon.aero/Topic13164.aspx
By TheHoff - 9/1/2014 9:16:00 AM
It would be nice to be able to plan (and show on chart) both a route through and around controlled airspace (or indeed danger area) so that if approval to transit is not received the alternative leg bypassing COS is already planned.
Marcus
By adhawkins - 9/1/2014 12:08:59 PM
Not tried it, but could you do this using the 'multi-leg' route features in the new version? Plan two routes with same start and end, but different en-route parts. Then when navigating you just select the route you want to follow.
Andy
