Pilots log should be editable
http://forums.skydemon.aero/Topic13156.aspx
By pseudonym - 8/29/2014 2:20:51 PM
As in navigation mode, it should be made easy to delete or to reorder single points from a route on the tabular representation of the route.
Practical problem: Route A->D. Then I drag the rubber band route to waypoint B, so the route is A->B->D
If I then press a (distant) point on the map, i can "insert in route" the point. Most of the time Skydemon assumes correctly where i want to insert it. But how if I don't want to fly A->B->C->D, but rather A->C->B->D.
I like the way govfr handles this.
