By VOZzer - 8/25/2014 3:08:08 PM
Hello all,
I appreciate this particular problem is not directly a Skydemon issue, but I assume many on the forum have managed to configure WMDC.
I want to be able to use the "sync" function in Skydemon. However, after downloading and installing WMDC, I connect my iPad, and WMDC refuses to recognise it under any circumstances. I have done all the obvious things including restarting WMDC with the iPad plugged in, restart PC, etc. The iPad is most certainly not in "Airplane Mode" or similar and so I would have thought that networking would not be a problem.
Regards,
Jack
By Tim Dawson - 9/1/2014 12:06:04 PM
You can't have two files with the same name on your device, the filesystem will not allow it, so not sure what's going on here. Can I see a screenshot of what it looks like afterwards and some exact steps so that I can attempt to reproduce it on the same device type?
