Flight INFO Regions Limits Frequency
http://forums.skydemon.aero/Topic13007.aspx
By Focha - 8/18/2014 9:35:58 PM
Hi there,
I would like to make a suggestion to be able to see more clearly the flight information regions limits, both lateral and vertical as well as the frequencies of those flight information regions.
That way would facilitate what the next region frequency is and when it will pass.
I don't know if there is a way to see it but I clearly can't find it.
Thank you for your help and attention.
By Focha - 8/21/2014 3:36:56 PM
Hi there Tim,
Thank you for your quick answer.
Yes, you are right. Flight Information Regions (FIRs) are clearly visible, also TMAs and CTAs are clearly visible.
What I mean is that we could have a way to see the Flight Information Service (FIS) frequencies more clearly in the map.
Thank you for your attention.
