Thanks it's working!
Best regards,
Pierre
Sky Painter (7/19/2014)
Under settings there is an option to lock the screen rotation. Before launching SD, turn your device the way you want it, access Auto Rotate in settings and select it. Your screen will then be locked in the chosen orientation until you again select Auto Rotate in settings.
