Airspace crossing when leg altitude is the same as lower airspace limit
http://forums.skydemon.aero/Topic12694.aspx
By bharb - 7/16/2014 7:40:31 PM
Hello!
Wenn planning a route at an altitude below an airspace which is exactly the lower limit of the airspace above I get a message that i will cross this airspace. For example, when planning a leg on 4500 ft and there is a class D airspace above from 4500 ft up I get this message. Would it be possible to fix this so that this will not be shown?
Thanks,
Bernhard.
By stevelup - 7/18/2014 11:27:58 AM
Why would you plan to fly exactly on the boundary?
I know that if I intend on passing under some airspace - at say 4500 feet, I'll plan for 4000.
