Unhandled exception when trying to connect to X-Plane 10
http://forums.skydemon.aero/Topic12667.aspx
By Fredrik - 7/13/2014 12:45:07 PM
I'm trying to set up SkyDemon as a GPS while I fly VFR in X Plane.
I have started X Plane and in the Net Connections did the steps described in http://www.skydemon.aero/plan/documentation/readytofly.htm
However, On my Nexus 7 tablet it says Waiting for Location Data, and when trying to connect in the PC application, I get the following callstack:
What am I doing wrong here?
System.Net.Sockets.SocketException: Only one usage of each socket address (protocol/network address/port) is normally permitted
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at Divelements.SkyDemon.Navigation.xc6602d31636a179f..ctor()
at Divelements.SkyDemon.x210ff09a2516b1a7.xfcc71472d5b2afbe(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at TD.SandBar.ToolbarItemBase.OnActivate()
at TD.SandBar.xf92605a24a69622a.x0ef5a9135fb0040c(TopLevelMenuItemBase xccb63ca5f63dc470, Boolean x674341222c6bbaba, Boolean x37b4525011735d95, Point x13d4cb8d1bd20347)
at TD.SandBar.TopLevelMenuItemBase.Show(Boolean select)
at TD.SandBar.ToolBar.OnItemPush(ToolbarItemBase item, Point position)
at TD.SandBar.ToolBar.OnMouseDown(MouseEventArgs e)
at TD.SandBar.MenuBar.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at TD.SandBar.ToolBar.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5477 (Win7SP1GDR.050727-5400)
SkyDemon
Assembly Version: 3.0.7.18534
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.Aviation
Assembly Version: 3.0.7.18528
Win32 Version: 3.0.7.0
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
System.Drawing
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.105.0
Win32 Version: 3.0.105.0
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Divelements.Mapping
Assembly Version: 3.0.7.18527
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
SandBar
Assembly Version: 1.4.3.2
Win32 Version: 1.4.3.2
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
