SkyDemon Flight Planning
Warnings and data roaming
http://forums.skydemon.aero/Topic11650.aspx
By JJA
4/3/2014 1:04:23 PM
I'm quite new to SkyDemon and have used it on a couple of flights which works great. I have two questions and hope you can help.
1. When planning a flight I see red warnings regarding I'm passing through class A airspace. The lower limit is 1500ft and my leg is at 1300ft. Is it possible to change any warning thresholds?
2. When flying abroad will it use a lot of internet data roaming for GPS/Maps/Navigation or is it pre-cached in some way?
Thanks in advance JJA.
By JJA
4/3/2014 9:31:17 PM
Thanks for your quick reply. I found the cause of the warning, it was in my route to the alternate airport.
