By Skydive007 - 3/30/2014 8:37:59 AM
since I use the last version of SKYDEMON and IOS 7,I got a lot of unexplainable system crashes during flight operation. A system crash occurs sporadically during zooming. A further problem is the indication of the correct elevation data. It shows you always a difference of round about more than 600 feet. The elevation is not steady, but jumps always up and down. Restarting the system, does not solve the problem (also if you don't make any action, the application crashes). The GPS signal quality is always good. The indicated ground speed is also accurate. For a better understanding of this problem, I have attached a little video
Best regards, Skydive007
By Tim Dawson - 4/1/2014 12:17:36 PM
SkyDemon will not give you a different altitude report than other systems, unless those other systems manipulate the output figure. To be sure, download GPS Device Data (a free app) which will show you exactly what your GPS device is sending to apps.
