possible feature
http://forums.skydemon.aero/Topic11587.aspx
By poorterp - 3/27/2014 8:15:45 AM
Hi skydemon team,
the following feature would be nice to have in VFR planning on IPAD and even during a flight.
Draw a radial from a VOR to a point on the map and show the distance and radial from the VOR.
Leave it on screen so its possible to do the same from a second VOR. Then you know two references
bearing/distance from a point to VORs so we an setup the VOR receivers in the plane as cross reference
Greetz Peter
By Pete - 4/29/2015 4:11:23 PM
If you set up the point as a waypoint, the plog will give you a vor/dme ref.
