concurrent use of skydemon on devices, keep getting an error
http://forums.skydemon.aero/Topic11380.aspx
By Wobblewing - 3/9/2014 8:56:33 PM
http://skydemon.aero/forums/Uploads/Images/7983d791-f54b-4b7a-b1ed-3df3.png
Hi. I keep getting the above (And attached) problem when logged into skydemon on more than one device. Specifically 3 android devices.
This shouldn't happen as far as I'm aware as I should be able to use up to 6 devices at once.
If I log out and back in again, I then get the same error on the other device that I was logged in on (if that makes sense?)
I am using the most recent version available on Google play...
Any ideas?
Andy
By stevelup - 3/10/2014 2:17:20 PM
The limit is two iOS devices, two Android devices and two PCs.
