VRP enhancement
http://forums.skydemon.aero/Topic1095.aspx
By pink leader - 9/15/2010 10:13:45 PM
Might I suggest that VRPs are a bit more visible on the map. I know you have tried very hard (and succeeded admirably) to make the maps as uncluttered as possible  .. and I very much appreciate that. But I use them a lot when route planning (ATC are v familiar with them). Also ATC will often use them for redirecting you to avoid other hotspots (gliders, PJ, etc). They also ask you to report when passing, abeam etc.
You cd even have 2 types  .. as now and "prominent". Select via preferences.
What do others think?
David
