Import Flight plans to Panel mounted Garmin GDU 370 / G3X GPS
http://forums.skydemon.aero/Topic10908.aspx
By design4p - 1/5/2014 7:18:57 PM
I am interested in purchasing an aircraft which has a Panel mounted Garmin GDU 370 / G3X GPS arrangement. Is it possible to transfer flight plans from my computer to this unit. I believe the unit has a SD card slot.
Any advise would be appreciated. John
By Tim Dawson - 1/9/2014 12:27:20 PM
I'm afraid I have no idea. SkyDemon can export your routes to the industry-standard GPX format, if that helps. If your Garmin device can read routes in that format from an SD card, that would be a potential solution to the problem.
