Instrument size
http://forums.skydemon.aero/Topic10231.aspx
By tonyhs - 9/8/2013 4:34:10 PM
I have looked through the documentation but cannot see if what I want to do is possible. I am using Skydemon on a 7" windows ce GPS. The instruments on the l/h side are a bit small for my eyes (ground speed, track etc). Is there a way of making that instrument bar wider so that the instrument readings are larger?
Tony
By stevelup - 9/9/2013 9:47:22 AM
Hi
If you follow the instructions here, you should be able to make your instruments the correct size.
