Flight Plan template.
Mariuszek
Mariuszek
Posts: 8, Visits: 324
Hi guys.
Would you find such a feature attractive?
After route planned, SD could generate pdf with flight plan template already filled.
Such a file could be easily printed out and faxed to briefing offices manually.
In some countries automatic filling and electronic submit (embedded already in skydemon) seems not to work.
Marcin
ZorgroZ
ZorgroZ
Posts: 23, Visits: 48
Yes, great idea!
jfw
jfw
Posts: 134, Visits: 485
When you start the process for submitting a flight plan you have a view of the FPL that will be submitted, so you already have that kind of info (altough not on a PDF format).
And no you do not have to submit the FPL by SD. I use this feature for preparing the FPL filing in advance.
Br,
Jf
Edited 4/4/2016 9:15:54 AM by jfw
Mariuszek
Mariuszek
I tried submit FPL electronically and briefing office didn't receive it. I think it's worth to add I reside in Poland.
I don't know, maybe I did something wrong with SD setup, or just Polish authorities are not ready to receive FPL in this format.
Two known to me channels which works in PL is either fax or via telephone call.
That's why the idea came to my mind.
Shifu
I would be extremely grateful if you could set out in detail, step by step, from the very beginning, how you go about filing your flight plans in this manner. Many thanks.
6575, SD 4.2.2
Many thanks Shifu. I'm in the UK, so I now have some homework to do to find out the special sending codes etc.
6575, SD 4.2.2
Many thanks. I'm with EE as it happens.
6575, SD 4.2.2
Hi Shifu
One more question if I may please – where do I find these special codes, should I change carriers at some time in the future?
6575, SD 4.2.2
Many thanks Shifu.
6575, SD 4.2.2
